how to re-re ignition igniter
Old Oct 14, 2009 | 05:33 PM
adrian92
Default how to re-re ignition igniter
got a 92 accord and after hours of scratching my head finally diagnosed a bad igniter. went to replace it and cant get the rotor off to access the igniter please help!!
Old Oct 14, 2009 | 06:01 PM
adrian92
anyone ?? please?? cant find it on the do it yourself forum!
Old Oct 14, 2009 | 06:16 PM
there should be one bolt that holds the rotor on the distributor shaft. Remove that bolt, and the rotor should slide off.
If the rotor is turned the wrong way, so you can't access this bolt easily, unplug the electrical connections to the distributor (there are two, I think). Then turn the key to the start position for a split second to turn the engine. You should be able to access the rotor bolt.
Old Oct 14, 2009 | 08:14 PM
adrian92
there is no bolt/screw on the rotor that i can see. I had my sister cranking the motor slowly but nothing there!!!!!!!
Old Oct 14, 2009 | 10:11 PM
adrian92
anyone feel free to chime in
Old Oct 15, 2009 | 10:03 AM
deserthonda's Avatar
get 2 screwdrivers and pry it out , sometimes ,it sticks pretty good ,,,been there , done that
barnfindhonda
May 20, 2013 06:37 PM
blumule
Mar 5, 2013 06:20 PM
1992ACCEX Tim
Jun 27, 2012 08:03 PM
deserthonda
Apr 7, 2007 05:45 PM
supa16
Sep 28, 2006 03:56 PM
