How to take turns
Old May 17, 2007 | 11:10 AM
abhijitgp's Avatar
Default How to take turns
Hello Experts,
I have been driving my stickshift car for over a year now, but lately read some driving tips that confused me. In regards to taking any turns, corners, etc. what is the shifting sequence? Assuming that I am in 4th gear and want to turn right, I used to shift to neutral, apply brakes, turn right, then shift back in 2nd or 3rd and accelarate. from the tips I read online, this seems to be the wrong technique.
Could I get some expert tips and tricks?
Thanks
Old May 17, 2007 | 12:02 PM
sir_nasty's Avatar
Default RE: How to take turns
depending on the corner there are a variety of ways to take them. As a general rule of thumb though you want to be either on the brake or on the gas at all times, no inbetween if you're coasting then you should either be holding your speed or slowing down....
The easiest way to take a corner and hold some speed is to downshift, then brake (if needed) BEFORE you start turning, then as you're coming close to reaching the apex of the corner (middle) lay back into the gas as hard as you can, in a front wheel drive car this will in trun "pull" you through the corner...
To be even faster you can start heel-toe shifting or double clutching or left foot braking but all of those little "tricks" will help but require a lot of practice to be good at.... google them for information if you care...
Old May 17, 2007 | 12:04 PM
tkundert2's Avatar
IMO, you want to stay in control, which means to slow before entering the turn and accelerate coming out of it. Avoid braking or slowing while turning (overloads the tires).
Old May 17, 2007 | 01:18 PM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: sir_nasty
nasty beat me to it. I was going to say the same thing. I usually double clutch. Heel-toe shifting is just too much of a pain in the @$$. The only way I would think it would be necessary is on a racetrack.
187Racing
Jun 29, 2010 01:19 AM
hondahonda
Jul 5, 2007 01:32 PM
thunder_x
Oct 22, 2006 06:16 PM
john_kim_
Aug 28, 2006 09:14 AM
boosted
Jan 25, 2006 08:13 AM
