Huge problem
Old Dec 13, 2011 | 01:23 PM
drew&dixon1718's Avatar
Exclamation Huge problem
while replacing the battery in my friends 04 coupe he put the battery in backwards and now the car is completely dead all that work is the horn and he said the tail lights. if u know the problem i need to find out asap b4 he messes anything else up.
Old Dec 13, 2011 | 01:38 PM
Peli's Avatar
Could be any number of things really, best idea would be to get it towed and have a shop look at it or look for a mechanic that will make the trip out to give you a free diagnosis for the cost of gas. Have you checked all your fuses? Alternator and fuses would be where I'd start.
Old Dec 13, 2011 | 01:41 PM
i checked the fuses and tried a number of things to get it started but still had no luck. and we got it towed back to his house i think ima see if i cant figure a little more out today in the light.
Old Dec 13, 2011 | 02:00 PM
Check the "main" fuses, theses are the higher amp (~100 or so, #22???) and usually have a clear top, located in the under hood fuse panel.
Old Dec 13, 2011 | 06:39 PM
Agree with my friend Poorman212. Do not connect the new battery while attempting to replace fuse, you do not want to accidentally bridge the connections with a screwdriver.
See attached images from owner's manual.
Attached Thumbnails Huge problem-large-fuse.jpg   Huge problem-under-hood-fuse-box.jpg
Old Dec 15, 2011 | 01:37 PM
turns out it was just the battery fuse we went to the local honda dealer and picked 1 up put it in and we were off haha thanks for the help guys especially redbull i never woulda looked for that 3 prong battery fuse if it wasnt for the pics u attached
Old Dec 15, 2011 | 02:15 PM
accordhybridowner's Avatar
My first time replacing a battery, I took a picture of the original battery before removing it, so I can be sure I put the new one in the right way... (You'd think it's simple enough... but nothing beats peace of mind.)
Old Dec 15, 2011 | 03:10 PM
Any thing you do that gives you peace of mind, like taking a picture is just fine..Digi cameras are just great , aren't they!.
Old Dec 16, 2011 | 12:31 PM
well the terminals were opposite on the new battery from the old. so he tried puttin it in so it went in easy instead of makin sure it was goin in right.
Yorty
Jan 7, 2008 09:54 AM
ElementK
Dec 7, 2007 10:51 AM
miami honda
Aug 5, 2007 06:01 PM
rydnlow1120
23
Jul 8, 2007 08:37 AM
Briggz
Mar 28, 2007 05:44 PM
