I need help I keep throwing code 9 off an on
Old Sep 12, 2011 | 12:01 PM
Jared-95hondaaccord's Avatar
Default I need help I keep throwing code 9 off an on
Okay I'm new here an I have a 95 Honda accord ex 4 door 4cyl.
An I keep throwing code 9 off an on some people told me it was the dizzy
I went an bought two brand new ones an both of them still kept throwing the code 9. I don't know what else to do so any help would be most appreciated
I don't know if this would cause it but there's alot of air coming out the gas tank when I take the gas cape off an I don't know why
Old Sep 12, 2011 | 12:25 PM
Check w/ search for other "code 9" threads. There have been several.
I had a similar experience w/ my 94Ex. After replacing distributor, I measured resistance of CYP sensor at new distributor connector (good), and again at the ECU connector (again good). This indicates the fault is in the ECU (damaged circuit board or jumper). From memory, the correct resistance range is 700-1000 ohms.
Used ECU's are inexpensive at ebay or car-part.com
Old Sep 12, 2011 | 01:15 PM
I checked the cyp an that measures good but do you know what pins to check on the ecu? An do you know why there's pressure building up in the tank?
Old Sep 12, 2011 | 05:33 PM
Better served in the General Tech section.
At the top of this section is a sticky-Common DIY Threads, there is a link on where to download a manual that will help.
For the CYP, I believe it is the wires that lead to B11 and B12....there is also test for ground from B11, 13 and 15.
Old Sep 12, 2011 | 08:47 PM
Got your PM, see if this helps. Again, please look in the "sticky" I ref for a link to a manual you can download. And as TX said, this could still turn out to be an issue with the ECU but you want to rule out everything else first....No I haven't looked at your other post about "fuel tank pressure" yet.
Attached Thumbnails I need help I keep throwing code 9 off an on-5th-gen-cyp-test.jpg
mishakol129
Mar 17, 2013 09:17 AM
Fat Ryan
Oct 21, 2011 06:54 PM
vancent60610
May 19, 2010 07:41 PM
duke16
Mar 9, 2006 08:18 PM
duke16
Mar 5, 2006 04:10 PM
