I need help with manual transmision
Old Nov 14, 2017 | 10:59 PM
ckharry's Avatar
Default Found my problem with '06!! Thanks folks!
Thanks to someone mentioning the pedal could be adjusted, I removed trim to check on that, and to my surprise, found that the clutch pedal bracket was completely fractured on the left side, allowing the bracket / pivot to move away from the firewall / master when the pedal was pressed (hope to attach pictures). The metal is pretty thin, but it being Sunday, knew a decent welder and didn't even have to purchase a new one.
When reassembled, it then shifted fine. Travel was not as much as I thought it would be though, 3/8" (9.5mm) but obviously enough. However, there was no way to "adjust" it. It seems on this '06, you get what you get. I guess hydraulic clutches are mostly self adjusting, like brakes?
The picture of the assembly removed- if you look carefully, you can even see the space between the horizontal piece and the vertical member.
Attached Thumbnails I need help with manual transmision-img_2733.jpg   I need help with manual transmision-img_2734.jpg   I need help with manual transmision-img_2732.jpg
Old Nov 15, 2017 | 07:42 AM
Wow, I don't remember hearing about that bracket breaking.
Shouldn't need adjustment, because the clutch hydraulic system equalizes when the pedal is up. No adjustment like on older cable clutches.
H3LLMAU5
Aug 8, 2015 08:08 PM
saanich
Sep 29, 2009 02:41 AM
kennilope
May 2, 2007 01:06 PM
bs9876
Jan 3, 2007 03:42 PM
John12345
Dec 19, 2006 04:40 PM
