I received the code I can you help
Old May 17, 2014 | 10:52 AM
03v6ex's Avatar
Default I received the code I can you help
Originally Posted by PAhonda
This is the information from an 03-06 Accord Shop Manual I found online.
1. Turn the ignition switch ON (II).
2. Press the AUTO button and then the OFF button. Continue to hold buttons down for 1 minute.
If there are any problems in the system, the temperature indicator will light up the segment (A through Q) corresponding to the error. The temperature indicator will then alternate every second between the displaying "88" (all segments lit) and the error code segment (A through Q).
NOTE: The system will only display the DTC when the AUTO and OFF buttons are pressed. If you release the buttons, the display will go blank. To return the display, simply press the AUTO then the OFF buttons again.
Old May 18, 2014 | 05:56 AM
Have a volt meter?
First thing you need to do is test the drivers air mix motor - for instructions, need to know if this is a 2 or 4 door car?
TexasHonda
Aug 5, 2015 07:44 AM
jasonfridlund
Jul 3, 2009 11:40 PM
jasonfridlund
Jul 2, 2009 02:28 AM
trukid21
Apr 23, 2007 02:16 AM
BostonPuppyDawg
Sep 25, 2006 09:55 PM
