I searched, but to no avail - ecu question.
Old Apr 9, 2007 | 12:01 AM
theBrewMeister's Avatar
Default I searched, but to no avail - ecu question.
Yeah, I know, I know, everyone has a question about the damn ecu. I was just curious as to how you know your ecu reset. After adding my exhaust system I pulled the back-up fuse (7.5) for a min or two with the key off. Then, i started her up and let her idle for about 10 mins. And so my question: Is there any signal, i.e. flashing light, dukes of hazzard horn tone, anything that indicates that the ecu did in fact reset and relearn. I'm sure that having some fancy peice of equipment would tell me but I do not work in a garage and have no access to it. Do I want to go to auto zone? No. Thanks!
Old Apr 9, 2007 | 12:19 AM
03Sleeper's Avatar
Default RE: I searched, but to no avail - ecu question.
Ummm....disconnect the battery. Usually, just unscrew the negative terminal. Resetting the ECU is like wiping the memory of someone so it thinks it came with all your aftermarket parts. Trickery and deception are a tuner's best friend...when battling the ECU.
Old Apr 9, 2007 | 02:48 PM
ORIGINAL: theBrewMeister
Your ECU reset procedure will work also. There is no feedback mechanism in the car to indicate an ECU reset other the the Check Engine Light. If it was On, it will be off when you reset. You could test for codes and determine that no codes are present, but you already know that when CEL is off.
BTW, what was nature of your repair? New catalytic converter, O2 sensor to repair a trouble code?
Good Luck
Old Apr 9, 2007 | 02:57 PM
poser_pilot6
You should be good to go, Brew. Thats the same method I used on mine, and I have a 94 LX also. I reset after I cleaned out my EGR ports, and it reset the CEL.
By the way, love your avatar. Its even funnier to me, because I have a Honda, and my wife has a Nissan Maxima lol.
pauldmonkey
Aug 25, 2024 12:11 PM
Rokkandy
Sep 2, 2011 03:08 PM
mwcky2204
Nov 15, 2010 10:21 AM
brinriha
Jul 2, 2008 09:28 PM
theBrewMeister
Apr 13, 2007 02:59 PM
