Idle Control Valve Repair & Replace: Help pls
Old Sep 13, 2013 | 10:23 AM
briggsrepair's Avatar
Default Idle Control Valve Repair & Replace: Help pls
04 EX, 2.4L, 130k miles.
Code: P0507, P2279
Symptoms: Random, repeated RPM reving, betweem 1500-2500 up and down. Occured in park, neutral, drive. Then the check engine light. New plugs, O2 sensors, filters, etc within 10k miles of this issue.
Normally I'd do the fix, but no time with work.
My local shop said repair and replace Idle Control Valve. Fine, I let them do it. All is well.
They decommended a "Fuel Service Cleanse." (I did not get details on what exactly they would do, other than hear them tell me it helps clean up carbons, B.S. B.S. etc.)
I declined.
Was a "fuel service cleanse" really necessary?? Thanks
Old Sep 13, 2013 | 11:56 AM
IACV's have been a service item on many Accords. Don't seem to see as many on 2003-2007 Accords, but may be early days yet.
It may not be dirty IACV, but can't hurt to clean.
You need a shop manual to run the diagnostics for those codes. Suggest a download from automanualsource ($22).
Old Sep 13, 2013 | 12:51 PM
Thanks. My question is:
Is a fuel service cleansing recommended with a IACV replacement?
Old Sep 13, 2013 | 01:00 PM
Fuel cleaning is easy money for shops. Fuel cleaners in all fuel you buy is adequate.
hondan1997
Jun 21, 2014 10:47 AM
darkgreen18290
Dec 29, 2012 11:42 AM
archangel_1988
Dec 13, 2011 11:43 PM
darkgreen18290
Oct 25, 2010 02:06 AM
TACORICAN
Aug 25, 2007 07:29 PM
