"idle to low!"
Old Mar 9, 2014 | 01:41 PM
Pbmanny's Avatar
Default "idle to low!"
I have a problem on my 2000 accord vtec its a v6 but it started to do it by its self whenever i turn it on and off couple times the next time i try start the engine the car turns on but then just turns off i retry to start it but have to hold the gas for a little and stays on but shakes and idles really low just like his does anyone know how fix it?
Old Mar 9, 2014 | 09:38 PM
First, go through this process. It covers the common things.
https://www.hondaaccordforum.com/for...e-speed-38734/
Old Mar 10, 2014 | 11:35 AM
Pbmanny's Avatar
Default Thank you
Hey thanks imma try this and it also has the check engine light my dad's friend put the code reader
And it said misfire in all the cylinders
Old Mar 10, 2014 | 03:39 PM
Random misfire can be ignition problem. How old are the spark plugs, what brand are they? How about the plug wires, distributor cap? (not sure if it has coil-on-plug yet in 2000?)
Old Mar 11, 2014 | 11:42 AM
Pbmanny's Avatar
Default Re
The sparks plugs are almost new I changed them right when it started messing up but didn't put NGK so car felt weak so I changed them again all 6 and installed NGK LASER ones and it has coils no distributor
Old Mar 12, 2014 | 06:56 PM
Sounds like heat soak, the v6's in this gen had/have an issue with this due to the design of the the fuel rails/lines.
I'll see if I can find the documents on this, my guess. Lets say you run the car until it is nice and warm....shut it off. Give it 10~15 minutes and when you re-start the car this issue happens?
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
