Idle Problem
Old Jan 6, 2015 | 06:57 AM
SoMdHonda's Avatar
Question Idle Problem
99 Accord LX 4 cylinder:
My idle would fluctuate up and down from neutral and drive to almost stall. So I tool apart the Throttle Body and and Idle Air Control Valve and cleaned them up. Got the carbon out of the TB butterfly and the IACV. Put it back together and now I cant even drive it. It stalls out when I put into drive and give alittle gas.
I bleed the air out of the radiator, and now uncertain if the IACV is bad or if its something else? I have checked for vacuum leak with spraying carb cleaner and seems ok. Also removed the fuse to reset the EMU.
When its at idle, the RPM's go up and down and is blow alittle black soot out the tail pipe. There is a very small black circle on the driveway from the exhaust. Im guessing from the carbon cleaning up?
thanks for your help.
Old Jan 6, 2015 | 07:50 AM
I moved your post to a separate thread for better attention. Read posting rules.
Add info on your Accord to your signature.
Up/down idle stability problem suggests IACV is working. A major air leak can cause idle cycling.
Suggest performing idle base setting procedure for your model.
Any Check Engine Light? If yes, what codes?
Old Jan 6, 2015 | 08:01 AM
SoMdHonda's Avatar
Sounds good!
Not sure about the codes because I can't drive the car. Im going to get a code reader tonight and get the codes...
Old Jan 6, 2015 | 01:47 PM
rockhoundrob's Avatar
Based on past experience, high idling or fluctuating idling has mostly been caused by a leak in a vacuum hose, or leak in a gasket at the throttle body.
Old Jan 7, 2015 | 09:22 AM
SoMdHonda's Avatar
Good News! I fixted my bone head problem: Just switched tps and map sensor. I guess I got them crossed when I took em off. FIXED
HatchJunki
Mar 9, 2013 08:23 AM
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
92Inspire
Aug 13, 2006 03:37 PM
fperezal
Jun 14, 2006 05:03 AM
