Idle Problem, but different from other post
Old Dec 28, 2007 | 01:31 PM
4thgenaccord88's Avatar
Default Idle Problem, but different from other post
My problem is when i start my car it idles at around 2100 RPM when its cold, and i kno this isnt normal, and when running and i put in drive and drive it for like 5 minutes or more, then i put it either in Neutral or Park, the idle will go up and down up and down...I dont kno what this could be, if anyone could help me it would be appreciated...btw i already replaced the Idle Air Control Valve, and this did not solve the problem, thanks....
Old Dec 28, 2007 | 03:15 PM
Default RE: Idle Problem, but different from other post
Replace or repair (might be a temporary fix though) the Fast Idle Thermo Valve. Its on the bottom of the throttle body housing. That is the valve that causes the idle to oscillate.
Here are a good set of instructions. https://www.hondaaccordforum.com/m_95855/tm.htm
EDIT: I WOULD NOT DO STEP 6 WITH THE LIGHTER!
Maybe Deserthonda or another moderator might want to make this a DIY fix or a sticky in the general tech help forum.
Old Dec 28, 2007 | 08:03 PM
hondadude's Avatar
the first thing you should do is try to figure out WHAT YEAR the car is.
There might be a sticker under the hood to help you find out the year of the car
Old Dec 29, 2007 | 12:41 PM
HondatechAV6's Avatar
ORIGINAL: hondadude
x2
what year is it?
Old Dec 29, 2007 | 02:50 PM
jose310's Avatar
im having the same problem, i tryid reseting the ecu and nothing.
Old Dec 29, 2007 | 03:03 PM
sir_nasty's Avatar
I know it should have been included but based on his name i'll bet it's a 4th gen 88. So please update your signature 4thgenaccord88 please.
Old Dec 29, 2007 | 10:10 PM
sorry lol, i did update it but i guess it didnt work, oops, its a 90 model, so the fast idle valve is likely to be it?
Old Dec 30, 2007 | 01:18 AM
the fast idle valve, if slightly open, will cause a bouncing idle. so will any vacuum leak. so will low coolant.
do you see/hear and vacuum leaks?
is the coolant level ok?(open the cold radiator and look inside)
can you feel vacuum on both throttle body ports when the engine is fully warmed up? vacuum on both ports is bad.
Old Dec 31, 2007 | 11:42 AM
thanks man ill check into these things, i justc ant figure it out, i guess im looking forward now to changing the valve cover seals...=(
LeftyJR
Dec 19, 2008 09:50 AM
Dec 11, 2008 05:36 PM
ziggy!talon
Apr 15, 2008 10:31 PM
kriegz99
Aug 11, 2007 08:41 AM
