Idle Stall and Stuck IACV Bolt problems
Old Sep 14, 2011 | 03:29 PM
renzki's Avatar
Nice! Ill try out these new suggestions. Thank you very much for helping noobies like me. Ill let you know how it goes
Thanks again!
Old Sep 14, 2011 | 08:10 PM
As PA said, get the PCV hose, wire to the IAC out of the way. From the drivers side, a pair of 6 inch vise grip pliers should fit in. Once out, install a new bolt.
Are/were you using 1/4 drive tools? The 1/4 10mm, 1/4 12mm six point sockets are my most common used tools I have.
Good luck and let us know how it goes.
Old Sep 15, 2011 | 10:55 AM
renzki's Avatar
Wow! The craftsman bolt-out thing worked like a charm (at the cost of 20 bucks)! The bolt turned easily the first I used it.
Ok now im seeing the screen on the IACV. Currently its really black. Sprayed WD-40 on it and waited and its still black. Should I expect it to turn silvery or what? I saw somewhere that it shouldnt be black
Thanks!
Old Sep 15, 2011 | 11:06 AM
I'd go with some with more "cleaning" power.
I'd use carb/tb cleaner or some use brake cleaner.
Old Sep 15, 2011 | 06:25 PM
Clean the ports in both directions, back side of throttle plate, and throttle bore as far as you can reach w/ an old toothbrush.
Old Sep 16, 2011 | 01:54 AM
Honda_Lady's Avatar
the Craftsman Bolt Out set works wonders. i have a set myself. once the bolt is out you can't reuse it like the others have said. if the end is rounded enough now so a wrench won't you will most likely need to use the bolt out set.
another tip with the PCV hose is you can use a flat tip screwdriver. it has worked for me before. sometimes using pliers squeezing the end together won't let the hose come off if it's on that tight. also using silicone helps with hoses.
Old Sep 16, 2011 | 04:06 AM
  #17
renzki's Avatar
Whats the specific name/type of the bolt that I should buy for replacement? These are available in places like autozone right?
Old Sep 16, 2011 | 06:35 PM
  #18
Looks like 8mm Dia X 45 mm long. Thread pitch isn't listed, I'm going to guess 1.25 mm. Take the old one with you to be sure.
mikelac
Jul 17, 2014 02:36 PM
ratimand
Sep 26, 2012 07:10 AM
acesn8s
Nov 6, 2011 05:14 PM
jfidelh
Aug 30, 2011 07:24 AM
bruggles1
Jan 11, 2011 02:46 PM
