ignition coil: no primary winding resistance
Old Sep 19, 2006 | 04:46 AM
deserthonda's Avatar
Default RE: ignition coil: no primary winding resistance
chk the TW sensor ..
Old Sep 19, 2006 | 02:43 PM
klyphman's Avatar
TW sensor is reading proper resistance when cool, but could it malfunction when it is hot?
Could a faulty O2 sensor cause this problem??
Old Sep 19, 2006 | 09:45 PM
it could.....when it wont start, pull the plugs out and see if they look like gas flouled ,,,,,,
.chk engine lite on?? you should chk for codes
Old Oct 6, 2006 | 11:09 AM
klyphman's Avatar
Been out of town lately. Here is update: A mehanic had no clue about the problem, but we did ascertain that in the no start condition, the engine is flooded, but would still cough to life briefly when the fuse for the alternator/fuel pump was pulled. When the fuse was reinserted, the engine instantly died.
Also, last night, the check engine light came on reading a code 6 for tw sensor. I will replace it and see if this causes the problem. Likely culprit?
Old Oct 11, 2006 | 08:53 PM
klyphman's Avatar
It was the TW sensor. Replaced it and reuns perfectly.
Thanks for the tips.
Old Oct 12, 2006 | 04:43 AM
ORIGINAL: klyphman
from the symptoms you described i had a feeling it was the TW sensor........Glad that it is fixed
Agate
Jul 20, 2015 10:59 AM
phantomgrey92
Oct 9, 2013 04:45 PM
Pat61
Apr 20, 2012 03:21 PM
57 T-Bird
Apr 28, 2010 11:50 AM
mtex5spd
Nov 22, 2004 03:47 PM
