Ignition problem
Old Jan 3, 2009 | 02:30 PM
yanxuhec's Avatar
Default Ignition problem
everything ( engine,radio ...)went off while I am driving at 80 miles /hour , sligthly turn the key it went back on , what could it be distributor ? my key ? ????
tks
Accord 99 Lx, 5 speed , 4cyl Vtec,200km
Old Jan 3, 2009 | 03:01 PM
Default RE: Ignition problem
likely the electrical portion of your ignition switch. There was a recall on the ignition switch, so you might want to call and ask your dealership about this.
When you start the car, try shaking the key to see if you can get it to stall while it is running.
Old Jan 5, 2009 | 11:41 AM
Flaky ignition switch is sorta common. The fact that you can make it come & go by wiggling the key pretty much proves that its the switch.
shehadehd
Sep 20, 2012 05:20 PM
david314
Oct 6, 2009 06:17 PM
clutch811
Sep 12, 2008 08:05 PM
R1ckyB0bbyyy
Sep 8, 2008 01:48 AM
stigedis
Jan 17, 2008 10:23 PM
