Im Confused?
Im Confused?
i have a 1997 Honda accord SE, it had been sitting for 5 months and today i jumped it off and drove it around and well, before i started it the DRL didn't work and the seat belt beeper didn't work, when i jumped it off the DRL worked and the seat belt beeped when i took off seat belt, but now neither don't work. why?
OK, DRL was mandatory in Canada back in 1997, so you have them. When I had a 1998 (wrong generation but maybe similar) the Canada car had a different wiring harness for headlamps, but it WAS covered in the Helm shop manual.
There's a DRL module somewhere, maybe under the hood, which is probably a relay & a resistor pack. The high-beam lamps are used at a lower voltage.
I would treat the headlights and chime as two different problems right now.
That was my mistake about the DRL and low beams.
For the DRL (which is more important), I remember reading that the solder joints could go bad on the DRL control unit that is under the dash. The repair was the same procedure as a main fuel relay solder repair.
My dad and i might be able to fix that, i think there's a short somewhere because the other night after i started this, only 1 high beam works and now neither and when all lights off the DRL indicator comes on (in the manual that means there a problem somewhere) and the high beam indicator at the same time, plus i have seen an accord where the turn signal comes on in the corner/parking lamp, mine don't do that. All the bulbs work cause i have taken them out and put them into my moms Camry (9006 too) and the high beams worked.
PJ_STYLES_95AccordEx
11-14-2006 12:48 AM
Leonhartilly
01-23-2006 11:03 AM
