Im thinking it steering...
Old May 21, 2010 | 05:19 PM
fortyfootelf's Avatar
Default Im thinking it steering...
Ok so many of yall know that ive had problems getting the ride to start... well that isnt the problem anymore. i fianally got it going and the battery somewhat charged along with the alternator. but now that it runs and is able to move, i have a wierd whining noise coming from the steering area. i know my brakes are shot but i also know that isnt where the noise is coming from. it is either the power steering or somewhere in the steering assembly. the funny thing is that it only happens whenever i am taking a left turn. my ps belt is brand new, along with the rest of the belts except the timing belt.
so my question to you all is what would cause my steering to whine? it sounds like rubber being mashed and dragged along a piece of glass. it isnt a terrible noise but i dont know the damages that it has to it.
im wondering if i should bleed out my power steering and refill it or what. any ideas are appreciated.
Old May 21, 2010 | 06:46 PM
You can try changing out the PS fluid. Replace with PS fluid from the Honda dealership.
You could also adjust the PS belt tension.
I remember your other long post when you first started. You should post your solution at the end of that thread to help out other people in the same situation as you were.
Old May 24, 2010 | 03:34 PM
ok i will post what all i did to it in order to get it working. i honestly havent had much time to get on here as much as i want. but ill get on that asap. and thank you for your thoughts on the steering.
Old May 24, 2010 | 04:51 PM
deserthonda's Avatar
i do not think that changing the fluid will solve your problem,, chk belt for proper tension, make sure reservoir has plenty of p/s fluid, also chk for a possible leak,, ( system sucking air " p/s pump hoses o-rings" )
Old May 25, 2010 | 09:29 AM
thanks desert. i went home last night and checked the fluid levels and they seemed to be fine. it was up to the full mark on the resoviour but i still am having problems. could it be my cv's?
98Accord220HP
Jul 12, 2006 01:00 AM
OkieDoke
Jul 11, 2006 11:29 PM
deserthonda
Jun 25, 2006 12:12 PM
morra1221
Mar 28, 2006 03:23 PM
Mike_EX
Jan 8, 2006 11:26 AM
