Immediately Stalls
Old May 15, 2012 | 12:45 PM
firefighter44's Avatar
Almost A Senior Member
hows the weather seal around your passenger door look, i had a leak around one of mine on another vehicle i had and it caused a pooling there when ever it rained hard
Old May 15, 2012 | 01:36 PM
deserthonda's Avatar
i have seen a lot of water leaks come from the windshield ( not enough sealant ) has windshield been replaced before ??
use some duct tape,, get a water hose , tape a part of the car at a time where you suspect leak is coming from and spray water, hopefully that will help you locate the leak,,
Old May 15, 2012 | 06:51 PM
Your a/c drain tube may be plugged up. Then the evaporator will not drain the water out the front of the firewall. Try freeing debris with a pipecleaner or a coat hanger. The drain tube comes out below the charcoal canister on your car.
Old May 16, 2012 | 12:03 PM
crispin's Avatar
Originally Posted by johntaps
I think it should be the I paid to spam this boardl. Due to the oil in the paid spammer link, current won’t be able to move through the spark plug, and back current will cause resistance and it damages the coil.
Please ignore everything this spammer wrote
Old May 16, 2012 | 12:10 PM
I think it should be the Honda Accord Ignition Coil. Due to the oil in the Honda Accord Spark Plug, current won’t be able to move through the spark plug, and back current will cause resistance and it damages the coil.
what is up with this guy, ive noticed that recently he has been popping in everywhere saying things that are either wrong, doesnt make any sense, or is something that has already been said or established in that thread. Can some one get rid of this guy or something?
Old May 16, 2012 | 12:14 PM
crispin's Avatar
Hopefully it is being worked on right now.
Old May 29, 2012 | 10:42 PM
  #17
dalejamin's Avatar
Update: I really appreciate all the help, guys. It rained a few days back and I was able to see where the leak was coming from. It appears to be from under/behind the glovebox, as indicated in the pic. Could this possibly be from the a/c drain tube?
Last edited by dalejamin; May 29, 2012 at 10:46 PM. Reason: Revised based on prior post.
Old May 30, 2012 | 07:59 PM
  #18
I'd say that is either from the windshield or from the "fresh" air intake.....ac drain tube is to the left of your hand....maybe 4~5 inches. on this gen you can pull the blower pretty easy, might have to pull back the carpet for the added room to drop the motor, then kind of look up into the ac/heater box.
regmike
Jul 20, 2013 11:28 PM
SFLACCORD
Feb 9, 2011 11:10 AM
dmatt40
Dec 21, 2009 07:07 AM
rph13107
Dec 16, 2008 11:05 AM
XZiler8r
Feb 16, 2007 09:15 PM
