intermittant stall
Old Oct 13, 2012 | 06:06 AM
Cecil's Avatar
Default intermittant stall
89 lxi starts and runs fine but if you shut it off it may or may not start back up. its getting spark but no fuel pressure, but will will get pressure and run fine after 20 minutes give or take
Old Oct 13, 2012 | 09:36 AM
hondadude's Avatar
With a test light you can check for 12V power to the fuel pump when the key is turned on.
If you have power for a couple seconds when the key is turned on, you can check for fuel pressure at the injector rail fitting.
djstylze
Jul 9, 2010 01:17 AM
cincyred5
Jun 23, 2009 07:00 AM
Rayman4449
May 14, 2008 11:29 PM
ufosearch
Apr 17, 2008 03:48 PM
MHFry1
Dec 23, 2007 05:30 PM
