Intermittent brake warning light
Old May 24, 2015 | 06:58 PM
shipo's Avatar
Default Intermittent brake warning light
Hey Gang,
About a week ago my 2001 V6 Accord EX had the "Brake" warning light illuminate on the dash. Thinking the brake fluid was low I added some (although the level wasn't what I'd call low), and the warning light went away; for about a day. Since then it illuminates and goes out in a very random pattern; not quite sure whether it is a fluid level sensor, the Parking Brake sensor, or something else entirely.
Any thoughts?
Old May 24, 2015 | 07:39 PM
The "BRAKE" indicator lamp issue can be caused by either:
  • brake fluid level switch intermittently stuck closed; providing ground to circuit
  • parking brake switch intermittently stuck closed; providing ground to circuit
  • faulty safety indicator circuit (built into gauge assembly)
  • intermittent short in wiring or circuit
Try disconnecting the Grn/Red wire at the brake fluid reservoir to try to isolate/narrow if that is the issue.
Old May 24, 2015 | 08:11 PM
I don't know if 2001 still has the actual float in the reservoir? Sometimes the float drags on the plastic mesh screen. I think some trimming on the screen (or a new screen) might have been the solution for some people.
It's not the "brake lamp" warning, right? That's a whole different warning.
Old May 24, 2015 | 08:33 PM
The 2001 still has the actual float in the reservoir.
MikeT
Aug 31, 2012 10:59 AM
dmjole
Aug 21, 2012 06:02 PM
hmr
Jul 24, 2011 07:19 AM
ropersc
Feb 18, 2011 03:09 PM
garyjatt13
Sep 10, 2009 10:18 AM
