Intermittent CEL following fuel fill-up
Old Nov 12, 2015 | 10:27 AM
shipo's Avatar
Default Intermittent CEL following fuel fill-up
Hey gang,
Over the last several months my 2001 V6 Accord EX will pop a CEL within say 75 miles of filling the tank with gas, but only sometimes.
The issue started in August, the CEL would remain on for most of the tank (or sometimes into the next tank) of fuel, and then self-clear. In mid-September I took a 2,000+ mile road trip; the CEL popped about 40 miles after filling the car and stayed on for the entire trip and into the second or third tank after getting back home; then it self cleared again.
Yesterday, once again following a fill-up, the light popped after ~30 miles, and was the first time since the September trip where the light was on.
I'm thinking this is probably EVAP related as there is no issue with drivability or fuel economy (I mean geez, I managed 31 mpg on the trip while driving between 75 and 80 with the A/C cranking the whole time). Naturally, every time I have a few moments to take it in to have the codes read, the light goes out.
Thoughts?
Old Nov 12, 2015 | 10:33 AM
Keep a OBD2 scanner w/ you and scan as soon as code pops.
I had problems on my MDX w/ fuel pressure sensor being intermittent.
No way to know what problem might be w/o code.
Old Nov 12, 2015 | 06:59 PM
The code should still be stored by the PCM even if the light is turned off.
Old Nov 12, 2015 | 08:56 PM
shipo's Avatar
Ordered a scanner today.
Old Nov 13, 2015 | 10:39 AM
rockhoundrob's Avatar
You can go to Autozone and they will scan it for free. My 2 cents... did you tighten the gas cap properly? Needs to click 2-3 times. or check gas cap for hairline cracks in the rubber.
Old Nov 13, 2015 | 10:57 AM
shipo's Avatar
Yup, was all over the gas cap thing back when it first happened.
Old Nov 13, 2015 | 01:39 PM
Dr. Drivability's Avatar
When you get the code pulled, if it's a P1457, suspect the EVAP bypass solenoid valve, common problem.
Old Nov 13, 2015 | 07:46 PM
UhOh's Avatar
similar problem with a Forester.
I got a damp paper towel and wiped down the rubber gasket and the tank fill lip (to get a good seal).
Took couple days but the idiot light went away.
Old Nov 17, 2015 | 02:38 PM
brocko's Avatar
Default Evap codes
Remember it's never ok to 'top off' modern cars. Just go until the pump shuts off.
The extra fuel gets into the tubing that collects the excess gas vapor and can eventually ruin the charcoal filled evap canister.
Old Nov 17, 2015 | 03:45 PM
shipo's Avatar
Advice I often give out and a practice I follow religiously.
tjmachado
Mar 26, 2024 06:10 PM
YeuEmMaiMai
Jul 16, 2006 11:12 AM
kgh31386
May 30, 2006 09:27 AM
