Jerky Trans on 96 ex
Old Mar 2, 2007 | 01:25 PM
Default RE: Jerky Trans on 96 ex
When your tach starts to fail, will the cruise control work properly? If no CC, the vehicle speed sensor (VSS) coul be faulty. A bad VSS might cause shifting problems, but I'm not sure about that. Hopefully, more experienced members can comment on this topic.
If the CC works without tach, then the tachometer might have some electrical of problem.
Old Mar 2, 2007 | 02:55 PM
Morgan's Avatar
Honda Service just told me the problem is not trans. It is a bad ignition coil! It is located inside the distributer. $91.00 Part and $76.00 for labor. I'll buy the part and put in in myself!!! Apparently, if your tach starts doing wierd stuff or stops, it is the coil....
Old Mar 2, 2007 | 08:28 PM
Morgan's Avatar
Correction!!! The coil is Not inside the distributor. It is external underneath the dist.. Engine is too hot to mess with now but it looks like the 10mm bolts that hold it on will be a bitch to get to..
Old Mar 3, 2007 | 03:15 PM
Morgan's Avatar
Done Deal!! Coil fixed everything. Tach works and trans doesn't bump around anymore. Strange that an ignition coil will fix a tachometer!! I thought Nissans were wierd!!! I love this stuff.
Mad Professor
Sep 14, 2014 07:14 PM
excamryguy
Jan 10, 2011 09:01 PM
Dag
Sep 12, 2009 08:50 AM
andx0r
Jun 1, 2009 06:58 AM
fiddleback
Mar 11, 2005 08:44 AM
