Sponsored by:
Sponsored by:
Need to replace sub frame for 2002 Accord
Old 02-22-2018, 06:57 PM
armchairavenger's Avatar
Default Need to replace sub frame for 2002 Accord
So I have a bent sub frame in my 2002 and am looking for a new part to replace it.
Except all of the sources that I'm looking at call the parts different things. Like, I've seen the phrase "front cross member" thrown around a bit. Are these the same thing? I found a guy who can do the actual repair if I get the part and I don't want to purchase the wrong thing, but none of the part names that I've found are that cut and dry. Can anyone tell me what I'm looking for exactly?
Old 02-22-2018, 09:20 PM
The front subframe principally consist of a front beam and a rear beam.
They are not the same thing as a front lower crossmember, which is part of the front bulkhead (which also is not the subframe). However, typically, part of the front bulkhead does also get damaged in a collision, etc.
Old 02-23-2018, 09:19 AM
I don't know if those are different for 2-door vs. 4-door. Automatic vs. Manual. V6 vs 4-cyl... etc.
Go to an online parts place like Majestic.
www(dot)hondaautomotiveparts(dot)com
Put in all your car's information.
Select "Body/Air Conditioning"
Select "Rear Beam / Cross Beam"
With the actual Honda part numbers, you don't care what name they use.
(for some reason Honda puts front & rear together on the same drawing, & they use the term "cross beam" for the corresponding frame at the rear suspension)
Old 02-23-2018, 01:55 PM
The Toecutter's Avatar
They're the same for 2 or 4 door, and AT or MT, but different for 4 cyl and V6. That's mainly due to engine/trans orientation in the car.
2manycars
05-14-2017 06:25 AM
naterj24
08-30-2016 10:15 PM
Muskoka
02-09-2016 10:04 AM
513Blackdogg
11-01-2014 12:38 AM
HondaFan II
04-14-2012 09:23 PM
Quick Reply: Need to replace sub frame for 2002 Accord
