just wondering
Old Feb 23, 2011 | 11:30 PM
bigbadwolf078's Avatar
Default just wondering
i have a 91 accord wagon....its got a bad f22a1 in it, the 2nd one its had...is there another motor i can buy to get this this running better without having to modify it? this is my dd 4 now and need it to be more reliable....very new to hondas and dont have a ton of $, can get another f22 for 350 but just wondering if theres something more reliable
Old Feb 23, 2011 | 11:36 PM
ive been told something about putting in a b1? dont even know what that comes in or what it is....maybe a vtec motor would b better? dont know need some advice
Old Feb 24, 2011 | 12:33 AM
The f22b1 engine is the 94-97 accord EX engine. The f22b2 is from the 94-97 LX/DX engine. The 90-93 accord engines are f22a#.
They are all basically the same 2.2L 4-cylinder engine. They are pretty rock solid engines.
How many miles did you put on the engine before the cylinder head cracked? How many miles does the engine have?
What happened that caused the first engine to need replacing?
Old Feb 28, 2011 | 11:19 PM
Hard to tell about the motor that was in it when I got it cuz it wasn't the original and the
One I got I'm not sure what happened to it cuz it was supposed to have just had the head
Done so go figure I guess just bad luck lol....just got a b1 that's has 115,000 on it for
$200 hope I can get it to work got to figure out how to make 3 round plugs equal 2
Rounds and square lol
Old Mar 1, 2011 | 12:06 AM
any suggestions on that?
Old Mar 1, 2011 | 12:32 AM
You will need an ECU from a 94-95 EX vehicle. The transmissions will have to match up as well (an ECU from an AT 94/95 for a 91 AT). You will need to wire up the vtec. Some the sensors will be in different locations, so you will have to modify the existing wiring harness.
From reading about H22 swaps, there is a difference between the 5th gen driver's side motor mount compared to the 4th generation. You will have to search around to see if this will be a problem and how to solve it.
Old Mar 1, 2011 | 12:39 AM
the motor i got has the full harness on it just dont have the computer....i think its an f22b1 would my tranny from my car fit it?
Old Mar 2, 2011 | 07:20 PM
Any F-series or H-series transmission will BOLT UP.
H-series will have different gearing to match the higher RPM of the H-engine, so you probably don't want that.
Automatic? (you never said) You need to watch compatibility of the trans computer like PA said.
Old Mar 2, 2011 | 07:31 PM
Its 5spd, what fun would an auto b lol .... Got it all in just worried about wiring it right
honDUHchick
Oct 9, 2011 12:11 PM
ronjr8102
Apr 30, 2011 12:13 PM
neueziel
Dec 27, 2008 02:34 PM
nafango2
Nov 27, 2007 11:43 AM
collbd01
May 14, 2007 09:49 PM
