Key in Ingntion Alarm
Old May 23, 2012 | 11:23 AM
Jack-Bikes's Avatar
Originally Posted by crispin
RedBull - I think you are missunderstanding the OP.
He is having a problem with the "KEY in LOCK while DOOR is OPEN" chime.
He is not referring to an "alarm system"
His chime, you know the ding ding ding, is going off even when there is no key in the ignition.
Exactly correct, ding, ding, ding...... and so on when the door is open. BTW: We are the original owners of this Honda. 102,000 miles I guess is relatively low.
Old May 23, 2012 | 06:48 PM
That's just broken in. I'm at 245K miles and still getting 28 mpg on my commute and 30+ on a trip (rare event for my spare car).
Old Feb 6, 2017 | 11:38 PM
Chaetophile's Avatar
Hello folks! I'm having this same problem with my 96 sedan.
I just replaced the entire ignition cylinder today, and the beeping is unchanged, so I don't think the fault is in the key cylinder itself.
There is a small unit with a circuit board and a solenoid that attaches to the ignition cylinder around the key opening. It contains the tiny green LEDs that illuminate the key opening, and I saw that it also has a tiny black plunge switch aimed at the key. There was a white plastic spacer in this section that had cracked in two, and appeared to be missing some tiny bits. I'm suspecting this may be the switch that operates the key-in-ignition chime.
I'll report back if I have any success.
By the way, the chime is 4 quick beeps, repeating. Plug that into a Morse Code translator and see what comes up. Yes, Honda engineers are that cool.
csh217
Jun 17, 2014 05:53 PM
lecompte51
Jul 3, 2013 01:38 AM
Zeerocks
Apr 19, 2013 12:26 PM
smmSTV
May 16, 2012 06:40 PM
prkarpi
May 30, 2009 02:58 AM
