Key + Key Fob Conversion to a Flip Key
Old Jun 16, 2014 | 12:58 PM
csh217's Avatar
Default Key + Key Fob Conversion to a Flip Key
I am looking to convert my key and key fob into a flip key. I am interested in doing this because it would take up less space in my pocket, is more convenient, and simply looks better.
Does anyone have any tips with a project such as this? successes or failures?
This is the key fob I am interested in purchasing: Click Here
I received a quote from a local locksmith. He would be able to cut the key for $6. So this project should be under $30.
This is for my 2002 Honda Accord SE
Old Jun 17, 2014 | 05:35 PM
The fun is going to be to get the new key programmed to the PCM.
Old Jun 17, 2014 | 05:53 PM
In the ebay seller's ad, the key fob has no transponder chip. It states, "You will have to take apart your old key to remove the transponder chip, then transfer the transponder chip and the remote electronics from your old remote into this case and have a locksmith cut the key"
On the 2002 Accord, the key transponder chip for the Immobilizer system is encased by the plastic for the key. You'll have to cut apart the plastic.
In addition, sounds like you'll have to transfer the electronics from your remote transmitter key fob for the security system into the ebay switch blade key fob.
This link shows how the Immobilizer system keys are a 6th gen Accord.
http://www.tegger.com/hondafaq/tsb/accord/x97-058e.pdf
This other link shows the remote transmitter for the 2002 Accord SE with factory installed security system.
http://www.tegger.com/hondafaq/misc/98-011.pdf/
There should be no PCM programming for the Immobilizer system if you use the original key transponder.
Barbas210
Oct 14, 2019 10:27 AM
azsmokey
Sep 6, 2012 02:32 PM
MizterKewl
Feb 2, 2011 01:16 AM
CoupeNotC
Jan 22, 2010 09:32 AM
danawatson
Dec 22, 2006 11:37 PM
