Key will not turn! Stranded
Old Apr 11, 2021 | 12:52 PM
Proskow's Avatar
Default Key will not turn! Stranded
Hey everyone been having an intermittent problem with my 2007 honda accord 2.4 . Lately when I try to start the car the key will go in but will not turn in any direction. I'm aware there is a steering lock or anti theft but I've tried to wiggle the steering wheel put my foot on the break in all sort of sequences and it will not turn over. I've done some research and people are saying the tumblers wear out. I've also contacted Honda and a whole steering lock ignition assembly is 500 bucks up here and I just can't afford that right now. I do have a second key and it doesn't make a difference. Is there any tricks I can do ?? Thank you all God bless.
Old Apr 11, 2021 | 01:36 PM
A temporary fix would be to spray wd40 on the lock. See if that frees up the tumblers.
A permanent fix is to pull the lock assembly and have a locksmith rebuild the lock with new tumblers that will match your original key.
Old Apr 11, 2021 | 01:41 PM
Proskow's Avatar
The thing with wd40 is it usually attracts dust and debris later on which would not be good inside the cylinder. That is a good idea for rebuilding the cylinder
Old Apr 11, 2021 | 02:15 PM
The WD40 would be temporary until you get the lock repaired. There is likely dirt/dust in there, so you may be able to free a stuck tumbler. Use a shop vac to remove most of the wd40.
Most likely a tumbler is worn or a spring is damaged and will need replaced.
Old Apr 11, 2021 | 02:19 PM
Proskow's Avatar
Sounds good. So where would I get this repaired ? I don't think the dealer will have tumblers to purchase . Is it a big job to remove this assembly ?
Old Apr 11, 2021 | 03:21 PM
You can call the dealership to find out. Call a local locksmith to see if they can do the repair or recommend a locksmith who can.
To save money, you probably have to remove the lock assembly. The top bolts are round, so you have to use a centerpunch on the edge and a chisel to remove the bolt. Look on youtube for video on how to remove the lock assembly. You may also find what is required to remove the lock cylinder.
tak06
Mar 10, 2017 05:15 PM
Bellbuoy
May 5, 2013 09:59 AM
Mic-Ill
Feb 9, 2013 02:36 PM
mtwallet
Jan 28, 2013 07:33 PM
91accordwagon
Apr 21, 2011 03:29 PM
