leaves blowing out of air vents
Old Sep 25, 2009 | 05:47 PM
hondafreak91c's Avatar
Question leaves blowing out of air vents
I have noticed that over the past few weeks that sometimes when I turn on the air conditioning in my car (1996 accord coupe lx at) that bits of leaves or other particles will blow out of the vents. this only happens for about the first 3 seconds that the car it on, after that no problems. anyone ever heard of this before?
Old Sep 25, 2009 | 06:08 PM
There is no air filter for the vents, so small leaves can get pulled into the vents. I had a lot of maple tree helicopters trapped in my evaporator when I repaired my a/c.
I would suggest that you vacuum any leaves on and under the cowl.
If that doesn't fix the problem, then you would have to discharge the a/c, remove/take apart/clean the evaporator box, reassemble, then recharge the a/c. I wouldn't do this, unless I had a/c problems to fix or there was enough leaves in there to clog the a/c drain.
Old Sep 25, 2009 | 06:10 PM
Wink
Hey PAHonda, that's just what I was going to tell him to do...
How you doin today?
Old Sep 26, 2009 | 03:06 PM
Angelo,
Thanks for agreeing with my advice.
I'm doing good right now.
Julia Hecky
Dec 30, 2022 06:33 PM
elessar78
Oct 24, 2010 02:51 PM
BHoward711
Apr 12, 2010 08:57 PM
00AccordLX5spd
Feb 17, 2008 03:14 PM
restrict187
May 20, 2007 08:23 AM
