Nothing blowing out of vents for AC or heat
Old Oct 14, 2010 | 07:24 AM
elessar78's Avatar
Default Nothing blowing out of vents for AC or heat
How do I troubleshoot this?
The lights come on for the AC controls. Do I check the fuses? If so, which ones? Under Hood Fuse/Relay box: Condenser Fan? Heater Motor?
Thanks.
I did a search, but some of the air conditioner questions seemed like they figured out already which part failed. I need to figure out first which part isn't working.
Old Oct 14, 2010 | 08:37 AM
Possibly your blower power transistor.
http://ww2 dot justnanswer dot com/uploads/acuramstr/2009-03-09_020540_Binder1.pdf
Old Oct 22, 2010 | 03:22 PM
elessar78's Avatar
Took it to a garage. Mechanic said it was the blower motor so he ordered the part and tried to install it and it's not the problem. He says it's something electrical between the blower and the ground. Any thoughts on what the problem could be?
He's trying to get his hands on an electrical schematic for a Honda, but won't have it until Monday. Any suggestions on where I can get one?
Old Oct 22, 2010 | 03:47 PM
Read these two threads that cover exactly the same thing you are dealing with. I would first try to get HVAC codes (pretty simple to do). Then you will probably have to replace/repair the transistor.
https://www.hondaaccordforum.com/for...ad.php?t=34292
https://www.hondaaccordforum.com/for...ad.php?t=34264
Old Oct 22, 2010 | 04:05 PM
Big John comes thru again..Thank You for your service
Old Oct 22, 2010 | 04:24 PM
Angelo - Thanks for the vote of confidence.
Old Oct 24, 2010 | 02:51 PM
You and all my other Mods are some of the very best..I Thank All of You...
Julia Hecky
Dec 30, 2022 06:33 PM
fris
Jun 18, 2013 02:16 PM
BHoward711
Apr 12, 2010 08:57 PM
hondafreak91c
Sep 26, 2009 03:06 PM
restrict187
May 20, 2007 08:23 AM
