Left blinkers not working, but light up with hazards
Old Feb 24, 2020 | 05:13 PM
Seanjordan20's Avatar
I have never gotten a bad relay but anything's possible
Old Feb 25, 2020 | 07:00 PM
aredd's Avatar
Doing more research is it possible that an aftermarket relay will not work properly? I've seen where Honda's and Nissan's are finicky like that.
Old Feb 25, 2020 | 07:21 PM
No a relay is a relay. I'm leaning towards the MUC. Everything else is checking out unless there is a break in the wire. I'm trying to find the muc layout to verify some things
Old Feb 25, 2020 | 07:37 PM
aredd's Avatar
thank you. Electrical is foreign territory to me. I did find out from the previous owner that the left side blinkers were was acting up on them as well.
Old Feb 26, 2020 | 05:38 PM
The 03 is wired completely different. The MICU is controlling the turn signal/hazard relay.
Troubleshooting properly would require some basic electrical testing on the pins of the fuse box, where you remove the relay and test for power or ground with a test light or volt meter. The tests are simple if you are good with using a volt meter.
Old Feb 28, 2020 | 08:58 AM
aredd's Avatar
I will give that a shot and follow up with my findings
Update: I applied a jumper from pin 2 to pin 6 and the left blinker lights came on and stayed solid. Am I to assume I have a bad relay? Seems the wiring is intact and working properly.
Old Mar 14, 2020 | 11:17 AM
  #17
What happens when you jump pin 6 to pin 3? Do the right lights turn on?
Pin 4 should have 10V with the key in the II position and the turn signal lever set to turn left.
Pin 5 will have 10V with the key in the II position and turn signal set to right blinkers.
Old Mar 14, 2020 | 01:23 PM
  #18
aredd's Avatar
I didn't think to do that side since the right signal turns on normally
Brandonsmills
Nov 27, 2017 08:51 PM
hondadriver08
Jan 24, 2014 06:38 AM
ETH13
Apr 19, 2013 07:54 PM
polaris80
Feb 14, 2013 08:50 PM
