Left side turn signal not working Honda accord 2006 vp
Old Mar 18, 2024 | 02:20 PM
Fxy1's Avatar
Default Driver side turn signal not working Honda accord 2006 vp
So I can’t seem to figure out this problem I’ve changed my combination switch and my relay the passenger side lasher works and when I put my hazards on the driver flasher seems to work as well I’ve checked the ground wires and all seems fine but when I switch the lever to turn left it’s like it’s not receiving power any ideas?
Old Mar 18, 2024 | 07:09 PM
The wiring is tricky on the newer accord setup, because there are two control units involved with the signal to the flasher relay. Since the bulb electrically works when you turn on the hazards, then the combination switch control unit or the wiring somewhere between the turn signal switch and the MICU is messd up.
When you replaced the combination switch, was the wiper switch also replaced?
Old Mar 21, 2024 | 11:11 AM
Fxy1's Avatar
no it wasn’t that was gonna be our next switch after seeing that the grounds were all working
Brandonsmills
Nov 27, 2017 08:51 PM
rogstar69
Jun 8, 2015 09:25 AM
polaris80
Feb 14, 2013 08:50 PM
bassack42
Oct 12, 2011 11:26 AM
rtsulliv4801
Feb 4, 2009 05:33 PM
