Left turn signal - [Confirmed Fix]
Old Sep 17, 2013 | 08:58 PM
derf41144's Avatar
Default Left turn signal - [Confirmed Fix]
Trying to figure out where to post questions 2003 Honda Accord EX, left turn signal dash indicator and front/rear signal lights stopped working today. Got new bulbs, but still not working. Is there a relay or fuse for just one side or the other? derf41144
Old Sep 17, 2013 | 09:04 PM
LOL, duplicate threads. Redbull deleted one, I deleted the other. So here's this one back again! Sorry about that.
Old Sep 17, 2013 | 09:10 PM
It may be a problem with the turn signal/hazard relay. Inside that relay is actually a circuit board and two separate relays.
https://www.hondaaccordforum.com/for...zard-relay-jpg
Old Sep 17, 2013 | 09:14 PM
derf41144's Avatar
is this located under the hood or under the dash?
Old Sep 17, 2013 | 09:17 PM
Under the dash. It can be a little difficult to pull out.
Old Sep 17, 2013 | 09:20 PM
derf41144's Avatar
I think i just saw an older post on this problem. Should be a challenge since I recently had knees replaced. Look out!?!?!?!?!
Old Sep 18, 2013 | 03:09 PM
derf41144's Avatar
Default FIXED - Left trun signal
Well as advised it was the trun signal/hazard relay ... and boy was it a challenge to get the old one out. However For anyone whom has the same problem when you go to buy one: Much cheaper on the internet than at local dealer if you can wait. Which I could not: cost $32.00 Plus there are 2 models to the relay depending on your Accord Vin number: Starting with 1 item is 38300-SDB-A03, if Vin starts with a J, then 38300-SDA-A02
Old Sep 18, 2013 | 03:10 PM
Thanks for reporting back that the problem was fixed.
Old Jun 10, 2014 | 11:39 AM
limeyrod's Avatar
Smile left turn signal.
Same problem- same solution, thanks to this thread.
2003 Accord EXL.
polaris80
Feb 14, 2013 08:50 PM
goofyninja
Jul 13, 2012 07:47 PM
bassack42
Oct 12, 2011 11:26 AM
JollyGreenMini
Sep 18, 2010 09:29 PM
nva_2007
Aug 20, 2009 12:25 AM
