95 Accord Condensor Ran Not Running
Old Jun 10, 2014 | 11:47 AM
salcat797's Avatar
Default 95 Accord Condensor Ran Not Running
Just wanted to say hello and hoping to get some help with my A/C issue.
I've had the car for 3 weeks now, has 178k miles, AT, runs good, just needs some TLC. I noticed the A/C condenser fan wasn't coming on, at all. Replaced with new fan, still not coming on. Fuse is good.
Where should I go next? The relay? Thermostatic switch?
Old Jun 10, 2014 | 01:22 PM
Welcome to HAF.
I will move thread to General Tech for better response.
w/ AC on, is radiator fan coming on, but not condensor fan? If yes, relay or fuse is likely. Check condensor fan relay near radiator on driver's side, wire colors, wht, grn, yel/wht, blu/yel. Check fuses 21 and 34 in underhood fuse box.
Aslo possibly a wiring/connector/ground fault, but less likely than fuse or relay. Check connector for 12V and ground. A ground fault could also cause fan to be inop.
Golddoor
Aug 17, 2011 05:10 PM
Plumcrazebody
Nov 16, 2010 08:48 PM
EEAntiStrat
May 24, 2010 03:58 PM
aneelley
Apr 19, 2010 07:40 PM
benzeye
Nov 6, 2008 08:38 PM
