Lights (and other electrical devices) go off and on randomly while driving now
Old Dec 28, 2011 | 01:05 PM
msproles's Avatar
Default Lights (and other electrical devices) go off and on randomly while driving now
For the past 2 days the electrical system in my 2005 Honda Accord 4cyl Sedan has started randomly going off and then back on.
The gap between off and on is typically 1-2 seconds, it has not as of yet impacted driving and it has not failed to come back on.
Most noticeable at night because of the lights, many times they don't go off as much as they just dim momentarily. The radio however will shut off and then back on completely, again, only taking a second or two to come back on.
Seems completely random, happens in stop and go traffic and interstate speeds, and it seems also random in frequency. Today only did it once, last night did it several times.
Not sure where to even start looking to figure out what is going on. Any tips or suggestions?
Thanks,
Michael
Old Dec 28, 2011 | 05:09 PM
I would stop by a parts store and have them test the battery and alternator.
You may also want to clean and tighten the battery cables.
Old Dec 28, 2011 | 06:05 PM
Russianred's Avatar
Arrow
Not sure about the newer Accords, but the 98-02 have a Multiplex Control Unit which is the electrical brain of the car. If the new ones have something similar, try checking out and trouble shooting that.
Old Dec 29, 2011 | 11:15 AM
msproles's Avatar
I stopped by the parts store and had them check the batt and alt. both came up good they said. The positive battery terminal was very corroded though and loose. When they moved it, part of it actually broke off so we went ahead and replaced it with a new terminal and cleaned up all the corrosion.
so far haven't had it happen again, though I haven't drove much since. Hopefully that fixes it and I can get away with a pretty cheap fix. If it keeps happening, I will post.
Thanks,
dewinlew
Jul 24, 2013 05:54 AM
bnwbass
Jul 9, 2013 05:35 PM
csh217
Apr 30, 2013 09:03 PM
hcorb29
Jan 22, 2012 02:51 PM
