Loud Rattle On Cold Start Up & While Driving
Old Nov 19, 2013 | 11:53 AM
This video from youtube may help. Pretty easy to implement.
Old Nov 19, 2013 | 04:26 PM
bsdubois's Avatar
Default Clicking/Tapping Noise was not VRC acutator-- bad rocker arm
I stumbled on this YouTube video by accident. This video was posted on YouTube by Jerryteck. I thought of the issues you are experiencing and decided to copy the link for your ready reference. (I hope I did not make another mistake and violate the term of use. I am new to the forum and need to read all this ins and outs. I apologize in advance if I made another error.)
The vehicle in the video is a 2011 Accord with clicking/tapping noise. Several times to the dealership and they eventually preformed the recall (please review text following the video). It helped until the next time the vehicle was cold and the engine was started. The Dealership eventually found the cause of the clicking/tapping. The engine had a defective rocker arm! You might watch the video and compare it to the sounds coming from you 2009 Accord.
I hope this helps!
Best of luck.
Old Nov 19, 2013 | 10:00 PM
Goldwinger's Avatar
Dropped the Accord off tonight, and I will let you guys know what happens with it.
Thanks all.
Old Nov 20, 2013 | 08:11 PM
Goldwinger's Avatar
bsdubois, I had about 6200 miles between oil changes, no oil leakage that I could see.
I dropped the accord off last night and showed them the video. They called me this morning and said that they had already changed the VTC Actuator, and had to check out the cam chain and timing belt, to see if they were bad. Then they called me back about 2:00 and said that it was done. (The only thing they changed was the VTC Actuator.) I just picked it up and brought it home and everything seems fine. The noise always happened in the morning on cold start ups, so I will see tomorrow morning.
Thanks for all of the input everybody.
Old Nov 20, 2013 | 08:14 PM
Goldwinger's Avatar
Thanks for the video Brian, I appreciate it.
Old Nov 20, 2013 | 08:17 PM
Glad they fixed it. There is no timing belt. The cam chain is the timing chain.
Old Nov 21, 2013 | 05:41 PM
  #17
bsdubois's Avatar
Default Glad they fixed it.
Goldwinger:
You are very welcome. You have a follow-up video in the event it is not completely repaired. I am glad your Honda Dealer finally listened to you and fixed the issue. I hope it is completely fixed and it is working correctly in the morning when it is started cold. Please drop a note after the am cold start.
Good luck with the Accord in the future.
Old Nov 23, 2013 | 10:26 PM
  #18
Goldwinger's Avatar
Ok so I started up the Accord this morning, ready to hear the loud metallic sound, and nothing but the car starting. Fantastic! It's fixed. Now if I could only get the surging fixed...
Old Nov 23, 2013 | 11:36 PM
  #19
Glad to see you have that problem fixed, now on to the next problem.
Old Nov 24, 2013 | 02:59 PM
  #20
bsdubois's Avatar
Default Accord Surging
Goldwinger, will please start a new thread on the surging and explain what the vehicle is doing, what speeds, what gear, hot, cold, etc.
Glad to see they fixed you service bulletin issue.
Good luck.
Cubbie
Apr 13, 2014 01:26 PM
cdarnt
Feb 23, 2011 08:15 PM
sjm5104
Jul 3, 2009 05:27 AM
HondaAccord93
Mar 18, 2009 08:40 PM
sbutler
Apr 23, 2008 11:46 AM
