Loud 'rumble' in 1993 Accord
Old Nov 27, 2006 | 12:34 PM
lamb
Default Loud 'rumble' in 1993 Accord
My 1993 Accord with 106,000 miles has recently developed a loud rumble coming from the front end.
Car is quiet when first started and for 30 seconds or so of driving (at low speed). Noise doesn't seem consistent with past exhaust system issues (middle and rear exhaust). Idle also seems off with idle 'speed' inconsistencies. Any ideas?
Old Nov 27, 2006 | 11:45 PM
hondadude's Avatar
Default RE: Loud 'rumble' in 1993 Accord
front motor mount?
FITV needs adjusted?
Old Nov 27, 2006 | 11:48 PM
poser_pilot6
ORIGINAL: hondadude
front motor mount?
For some reason, Im drawing a blank on FITV right now... And I know I know this one... Fix IT Valve? LoL
Old Nov 28, 2006 | 02:47 AM
deserthonda's Avatar
is the rumbling noise while car is moving ?? standing still or both ?
make sure throttle body is clean,, possible iacv issues ,
remove throttle body intake hose, open the throttle plate and make sure that it is clean,, also, fuly remove the idle adjust screw, spray carb clean in the hole a few times, reinstall screw and readjust idle speed
Old Nov 28, 2006 | 10:51 AM
lamb
The rumble is only when the car is moving but the idle is variable. Perhaps two separate issues???
Old Nov 29, 2006 | 11:34 AM
if rumble is only when car moving,, i would chk the tires, wheel bearings and possibly an internal tranny noise ??
..if AT . put it in N while driving see if noise goes away ...
if manual tranny push clutch in and out see if noise changes
Old Nov 29, 2006 | 02:45 PM
YeuEmMaiMai's Avatar
differential in transmission or TQ coverter failure would be first two things I would look at
wheel bearings? but not likely to go bad at only 10XK
camasaki
Dec 10, 2014 08:08 PM
Fizgig
May 4, 2010 07:37 AM
JohnnyBoy
Apr 2, 2010 09:42 PM
slimmike
Jun 26, 2008 11:13 AM
o4vroom
Dec 23, 2005 04:09 PM
