Lousy mileage problem
Old Feb 10, 2008 | 10:59 AM
RobCo
Default Lousy mileage problem
2005 Accord EX V6 AT. Only 3600 miles on it(yes thats three thousand six hundred)
Car is in great shape but it's getting terrible mileage, avg barely 18+ combined. Car did
sit for a long time. Changed oil, checked to see if brakes were binding, had two tanks of
of fresh gas. I'M not pushing the car hard or anything...Any suggestions short of heading to the dealer?
(under warranty)
Rob
Old Feb 10, 2008 | 12:41 PM
62maxx's Avatar
Default RE: Lousy mileage problem
Rob, how long did it sit? Was it garaged insideor out in the weather? This is "way out there" but make sure the air filter & the connecting air tubesdidnt haveresident mousenesting in there clogging everything up. It happened to one of my other cars.
I have a 98 Accord 2.3, 115K mi. I get 26 mpg combined @ 75 mph/hwy speeds.I make sure my tire pressure is accurateand have a K&N air filter.
Even with the low miles, check your spark plugs for the heck of it to see if they are burning clean &inspect the plug wires. Check the trans fluid level to make sure it's not "underfilled" causing more frictionHope this helps, let me know.
Old Feb 10, 2008 | 10:40 PM
HondatechAV6's Avatar
read on, lets see how many you abuse [8D]:
Set Correct Tire Pressures - Use an accurate
tire gauge to set the tire pressures to the
recommended values listed on the driver’s
doorjamb sticker. These values are the
recommended cold inflation pressures that are
the best compromise for ride quality, steering
feel, handling, and fuel economy. When
replacing tires, always go with OEM tires,
they’re optimized for low rolling resistance.
Use the Correct Engine Oil - A higher
viscosity engine oil increases internal engine
drag, and that reduces fuel mileage. Always
use the recommended engine oil for your
vehicle.
Accelerate Moderately and Smoothly -
Avoid pressing the accelerator pedal
excessively. Hard acceleration burns a lot of
fuel. Very slow acceleration keeps the
transmission in its lower gears too long, which
also increases fuel consumption. Moderate,
smooth acceleration gives the best fuel
economy. If the vehicle has an M/T, you can
boost your fuel economy by upshifting as
early as possible.
Avoid Stop-and-Go Driving - Anticipate
traffic signals to keep the vehicle’s momentum
going. Avoid unnecessary stops and starts.
Don’t tailgate; hugging the bumper in front of
you forces you to make the same stops and
starts as the vehicle that bumper’s bolted to.
Use the cruise control as much as possible to
keep your speed consistent.
Minimize Braking - Every time you brake
while driving, you have to accelerate again,
and that uses fuel. When decelerating, take
your foot off of the accelerator pedal or use
light braking. In hybrid vehicles, decelerating
or light braking charges up the IMA battery so
the kinetic energy can be used again when
accelerating.
Use the ECON Button (Insight and Civic
Hybrid models only)
- Make use of the
ECON
button. When you’re in ECON mode,
and with the A/C running, the Auto Idle Stop
feature is active.
Use A/C Sparingly - The engine works
harder when the A/C is running, and that
reduces your fuel mileage. Turn on the A/C
only when you really need it. If the vehicle has
climate control, select the warmest
temperature that’s still comfortable.
Reduce Speed - Aerodynamic drag has a big
effect on fuel mileage at speeds above
45 mph
. Reduce your speed and you reduce
the drag. Trailers, cartop carriers, roof racks,
and bike racks are also big contributors to
increased drag.
Reduce Vehicle Weight - Unnecessary items
in the vehicle add weight. That makes the
engine work harder and use more fuel.
Remove the stuff you don’t need from the
passenger compartment, trunk, or cargo area.
Use a Block Heater in Cold Weather - As
the air temperature drops, more fuel is wasted
heating up the engine to its normal operating
temperature after a cold start, and the engine
oil is thicker, increasing internal engine drag.
Also, at temperatures below
40° to 50°F, fuel
doesn’t vaporize properly, so more of it must
be used for the engine to run properly during
warm-up. A block heater helps keep both the
engine and the engine oil warm and reduces
the extra fuel needed at colder temperatures.
Avoid Short Trips If Possible - The engine
uses a lot of fuel to warm up to its normal
operating temperature (about
180°F), and it
has to deal with higher internal friction before
it does. The shorter the trip, the more fuel
that’s wasted warming up the engine and is
lost to higher internal engine friction. For short
trips, try walking or bicycling if you can. If you
need to drive, keep in mind your fuel
economy will drop quite a bit. This is
especially true if you’re making those short
trips on a cold day or if you’re making them on
a hot day and you’re running the A/C to
quickly cool down the vehicle. Such
conditions can easily reduce your fuel
economy by more than
25 percent.
Old Feb 11, 2008 | 06:15 AM
drsquash
'Don't mean to open Pandora's box of troubles; but would converting to synthetic oil improve mpg data?
The Old Professor
Old Feb 11, 2008 | 07:14 AM
Synthetic oil would have the proper viscosity once it's warmed up. It should help when starting a very cold engine since it doesn't thicken as much at temperaturesbelow the 0°C point where the "W" viscosity point is specified.
But it's a very small improvement compared to driving habits.
Old Feb 18, 2008 | 03:14 PM
tcheema's Avatar
ive got a 2004 ex v6 with 42K. I have similar problems to what the original poster had. I bought it with 27K and the mileage I put on it is about 70% highway. City mileage was bearable(probably around 16-17 mpg and highway was around 24 -25. Recently, since the winter started and I was on Christmas break (I'm in college and used it to commute last semester) the car was driven locally. Since then, whether it was warm here or cold (North Jersey) I've gotten terrible mileage. I usually get $20 whenever I get gas and that gives the car gets almost half a tank sometimes it go through that within 50-75 miles of driving. Now my sister also drives this and she is a terrible driver(constant brake riding, stop and go driving) and I suspect that might be part of the reason for the low mileage, but when it seems like I'm getting 12-13 mpg sometimes I just don't know what to do. I've changed the oil twice(every 7K about) and plan on getting the transmission serviced at 45K with another oil change. I've had the car serviced at a local castrol center but plan on going to the dealer now. I'm only 18 and I drive better than most of my friends(don't real put my foot on the gas hard, and coast when I can, no rash driving) but even then I know I'm not going to get the 21 city and 30 highway. Any more advice will help. Would having 2 or 3 different drivers affect the mileage negatively? BTW on a recent trip to PA I got roughly 27-28 mpg with the cruise control on at 70 mph. I think thats the best I've ever seen. Also, it seems like the fuel gage is highly inaccurate b/c when it goes down it goes down in intervals of 2 or 3 little bars. Besides this I love the car, the only things I have to get looked at are the driver seat moves under hard braking and the key doesnt come out of the ignition unless I tap the shifter a little bit. It has the perfect amount of power, size, and features. So basically I only have real problem with city driving mileage.
Old Feb 18, 2008 | 03:16 PM
tcheema's Avatar
wow that was a long post...sorry about that guys
Old Feb 18, 2008 | 09:25 PM
Driving habits are so important to mileage that it's always risky to compare.
But try this...
Find a flat empty parking lot. Get going straight, very slow, then put it in neutral. You're looking for a feeling of drag which will be easiest to tell just in the fewmoments before it coasts to a complete stop.
Then (if you feel any drag) you'll be looking for brakes that drag, or bad wheel bearings, or stuff like that.
Some cars have sticky, rusty handbrake cables so the handbrake is always dragging. Sometimes it's stuck caliper slide pins or other stuff like that.
Tires at the proper pressure?
Old Feb 19, 2008 | 01:08 PM
falkore24's Avatar
tcheema: I think there is a microswitch in the tranny shifter that unlocks the key from the ignition. This is so that you can't take the key out without the car in park. This switch might need adjustment or replacement, but should be an easy repair to save you a little agrivation.
One thing about mileage that hasn't been mentioned. EPA ratings do not use blended gas. Most of the gas in the country right now is a blend of gasoline and ethanol. Ethanol hurts your mileage!!!!
Lower Heating Values (@ 60 deg. F):
Gasoline = 116,090 Btu/gal.
Ethanol = 76,330 Btu/gal
Good Chart for Fuel Properties
jkp
Aug 26, 2017 11:11 PM
steak2286
Nov 14, 2011 01:55 AM
TexasCJ7
Mar 7, 2007 07:27 PM
BigPete
Apr 18, 2006 07:04 PM
RBG
Sep 24, 2005 05:38 PM
