Low Oil Pressure At Idle
Old Jul 2, 2012 | 08:18 PM
curtie94's Avatar
Default Low Oil Pressure At Idle
K so heres the issue. my 1991 honda accord seems to have low oil pressure. AT idle on my mechanical gauge, I get 5-7. But when the cooling fan comes on the pressure rises to about 8psi. At 1000 rpms I get about 12psi. But today was 80F. When it was 90F out I had lower pressure and at 3000 rpms I had maybe 55-60psi.
Im running 10w30 right now should I step it up a grade or 2.
I checked the oil level and it was about half a quart overfilled, and there was air bubbles on the dip stick, should I drain some oil?
Or is it the bearings.
Old Jul 2, 2012 | 11:22 PM
UhOh's Avatar
55-60 psig oil @ freeway speeds sounds very good.
all oil pressures drop at idle. I'd just drive it.
I tried to worrying about the same thiing with an old car once and
found heavier oil viscosity made no real difference: surprised me.
Old Jul 3, 2012 | 01:25 AM
Let's see if we get more input on this post...
Old Jul 3, 2012 | 07:34 AM
Silver6gen's Avatar
so you're not experiencing anything else unusual? My gauge reads about 10-15 at idle possibly lower when warm. when cruising at 60mph its around 50-65psi and when accelerating over 4000 rpm it pegs out at 100psi
I know our engines use higher than average oil pressure but I wouldn’t be worried about your idle issues. In fact i'd lean more towards your gauge not giving you correct info (not calibrated correctly?) rather than the car being faulty.
Old Jul 3, 2012 | 05:48 PM
curtie94's Avatar
I don't get 50-65 cruising at 60. I get like 40-45. And my gauge pegs out at 5-6000 rpms.
I also used to get the oil light to come on at idle before I removed it. I think im going to change my oil tonight. With 3 quarts of 10w-40 and 1 quart of 20w-50.
Old Jul 4, 2012 | 07:52 PM
curtie94's Avatar
Ok so today I replaced my oil with 3 quarts of 10w40 and one of 20w50. My pressure at idle is now 12-14 and I reach 50 at around 2000.
eduard
May 9, 2013 12:11 AM
curtie94
Jun 23, 2012 07:52 PM
piconrule
Jul 24, 2009 02:38 PM
EricG
Jan 26, 2008 06:25 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
