Lucas made car go braap blah blah die
Old May 28, 2009 | 11:07 AM
Jmoney's Avatar
Default Lucas made car go braap blah blah die
put a bottle of that lucas fuel injection cleaner in my car friend had 10 bottles of it atleast and ever since then if my car gets to half tank of gas or lower it stalls out when i brake to a stop and sometimes pain in the *BUTT* to start after stalling out i checked the IAC and the EGR they are cleaned out adjusted everything still have this problem please help this is embarrassing and frustrating runs fine all through RPMs though
Old May 28, 2009 | 12:23 PM
Smile Hello Member...
I use the Lucas injecter cleaner my self and have never had problems with it, but I realize that you could be having a problem?. The bottle states that it covers 25 gallons of fuel per bottle, so you did pour in way to much for that first time use.
Have you filled up your tank with gas since you put in that whole bottle ?
Old May 28, 2009 | 12:37 PM
finch13's Avatar
I agree with Angelo, you probably put too much in. Too much Seafoam in the gas tank will make the engine stumble as well. You may want to refill the tank and put in some octane booster/fuel stabilizer for 1 tank and see if you can run the rest of the injector cleaner out.
Old May 28, 2009 | 01:54 PM
Wink
Finch has another good product SeaFoam...those two products are two of the very best products on the market...
Old May 29, 2009 | 02:14 PM
Jmoney's Avatar
i did put the whole bottle in yes it never starts doing it until i get to half tank of gas and the lower the gas gets the worse it does it ive filled it up past half to almost full 3 times now same result it runs awesome in high rpms and only dies if i brake semi hard like kind of at a red light but if i take 500 feet to slow down nothing.
Old Jun 1, 2009 | 10:03 AM
drummer1279's Avatar
did you use one of the large bottles? I also use the smaller bottles of it and never had an issue
dankent
Apr 2, 2011 05:21 PM
Lx-i_but_no_Lexus
Jan 22, 2010 02:05 AM
kellysa111
Jul 12, 2009 06:10 PM
apaksl
Feb 2, 2008 08:37 AM
