Lucas Transmission Fix for my accord.
Old Nov 5, 2007 | 02:19 PM
xaznxeclipsex's Avatar
Default Lucas Transmission Fix for my accord.
My 94 with auto tranny has 160K, it shifts hard and sometimes makes a noise, I got a tranny oil change 2 months ago, and I want to add a bottle of Lucas Transmission Fix, can I add the bottle of Lucas without draining some ATF fluid out? Will it be too much fluid without draining some and cause tranny to some how overfill and leak out the extra fluid? Thanks!!
Old Nov 5, 2007 | 02:22 PM
Default opps hit reply my accident.
Old Nov 5, 2007 | 03:00 PM
00AccordLX5spd's Avatar
Registered User
Default RE: opps hit reply my accident.
I have read posts recommending you not add that stuff at all. I have never had any luck with it in the past.
If you do add it(your decision) I believe you will need to drain some fluid first if your trans is totally full.
I added something like that to myMustang a while backcause it was leaking trans fluid - it didn't do anything I could tell.
Old Nov 5, 2007 | 03:12 PM
It've searched on this forum, and seems no one has tried the trans fix, so i figured i'd give it a try.
Old Nov 5, 2007 | 03:16 PM
Registered User
ORIGINAL: 00AccordLX5spd
I was wrong: https://www.hondaaccordforum.com/m_19196/tm.htm
The stuff I used was not Lucas brand. it was a cheap off brand "stop leak" fluid for my mustang. maybe I'll try some Lucas in my Mustang now!
Old Nov 5, 2007 | 03:44 PM
brittanym06's Avatar
I used Lucas in my Nissan Maxima. The transmission had a lot of problems already but it stopped most of the leaking and made it shift smoother. Mine was low on fluid already soI just added it without draining the old stuff. I think on the bottle it tells you to add half the bottle to existing fluid...that's my two cents. good luck to ya.
Old Nov 5, 2007 | 04:22 PM
drummer1279's Avatar
if your tranny is totally full then yes you will need to drain some fluid out because that entire bottle of Lucas replaces a full pint of tranny fluid. its good stuff also give AMSOIL, Mobil 1 Full Synthetic or the Castrol Import Multi-Vehicle tranny fluid a shot they all work well in Honda
Old Nov 5, 2007 | 04:45 PM
nafango2's Avatar
i say just spend the extra $12 and get two quarts of OEM fluid, couldnt hurt to get some more of the old fluid out.
sawtooth500
Jul 6, 2011 05:21 PM
Accord2012
Mar 15, 2011 11:57 PM
across55
Nov 5, 2009 12:36 PM
Mar 31, 2007 02:03 AM
nixalot
Jun 10, 2006 05:28 AM
