Lunging on acceleration/deceleration & slight vibration
Old Dec 15, 2009 | 04:27 PM
JonnyQuest
Default Lunging on acceleration/deceleration & slight vibration
99 Accord 5-speed which I just bought 3 days ago. Noticed under acceleration and decelerating a lunging, almost as if it needed the fuel injection cleaned badly.
Also, while on the highway where it's most noticeable, a slight vibration which I feel about every 5 seconds, consistently. And it's very subtle, not terribly noticeable, but I can feel it.
Also, the check engine light is on, haven't run the codes though.
My untrained mechanical ideas are maybe motor mounts??
Old Dec 15, 2009 | 04:39 PM
Get the code(s) to help identify problems. Stop by an autozone, have them read the codes, then post the actual code on here (like P1234).
Old Dec 16, 2009 | 06:46 AM
Grab the valve cover & shake it to check the engine mounts. Loose mounts won't set off the CEL.
Has it been sitting in a driveway with a forsale sign for very long? Stale gas? Or maybe gas that's NOT winter-blend? If you're lucky it might get better when you use the gas & refill.
Old Dec 16, 2009 | 08:05 PM
JonnyQuest
The CEL code is P1457
Any chance this may be it?
Old Dec 17, 2009 | 07:09 AM
P1457 = EVAP system leak; in the canister section of the EVAP system
That "shouldn't" do anything that you can feel. There's a thread about it over in the DIY section.
However... If you're in the habit of over-filling the gas tank, the charcoal in that EVAP canister might get saturated. Then that might cause both the lunging and the P1457.
Robbierobb
Nov 15, 2013 05:53 AM
echostate
Apr 12, 2012 11:57 PM
frmrpriownr
Nov 15, 2011 09:50 AM
RandyJW
Nov 12, 2011 10:23 PM
cmoorevt
Feb 20, 2008 02:55 PM
