Main Relay ?
Old Jan 5, 2013 | 07:39 PM
timmy2dollar's Avatar
Default Main Relay ?
What are the Symptoms of a bad Main fuel Relay ?
90 accord starts & runs fine till it Warms up then starts cutting out But never dies !
Also there is no Codes Stored
Old Jan 5, 2013 | 08:14 PM
You don't have the symptoms of a bad main relay. If the main relay was not working, the fuel pump would not get power and the engine would not run.
Old Jan 6, 2013 | 12:11 AM
go-part's Avatar
Former Sponsor
We cant exactly rule out the main relay, you can test it if you would like to
Testing a Honda Main Relay - Honda Main Relay Test - How To Test a Main Relay
Its just more likely that you have a bad ignition coil..
Old Jan 6, 2013 | 03:08 AM
Silver6gen's Avatar
A relay going bad can cause your car to stall out during longer drives. Cranking won't restart it until it has cooled enough. People some times misdiagnose this as faulty fuel pump or bad dizzy though.
What is going on with your car?
Old Jan 6, 2013 | 12:30 PM
It seems that Honda main relay problems will "USUALLY" not stall a running engine. They show up when starting the engine. But I can't really explain a reason for that, it's just the conventional story with Hondas. So you can't really rule out a problem with the main relay, but it doesn't fit perfectly.
Old Jan 6, 2013 | 07:06 PM
Thanks for all the replys everyone im thinking its the Distributor ..
skareb
Aug 26, 2010 06:41 AM
greg05
Aug 31, 2009 05:32 PM
jrcastro
Jun 26, 2006 09:20 PM
deserthonda
May 12, 2006 03:44 AM
Cleric
Dec 26, 2005 09:09 PM
