main relay wont switch for fuel pump
Old Oct 14, 2011 | 03:42 PM
crazylegs12's Avatar
Default main relay wont switch for fuel pump
I did a h22a swap on my 91 accord. Everything is good all the wiring and plugs are connected. But my main relay won't work to switch on my fuel pump. i checked and I'm getting voltage coming in but none out. I disconnected the relay and powered by hand and it works. I pumped the pins and the fuel pump works. Just don't understand why it won't click over when th relay is in. Help me out
Old Oct 14, 2011 | 07:44 PM
So you have sprak? Confirmed how?
What ECU and Dist are you using?
Sounds more like you should be testing the INPUTS to the relay and not the relay.
Where did you mount the main ecu ground?
Old Oct 15, 2011 | 07:48 AM
Either a bad relay or possible ground missing to MFR.
Malcontent
Jun 29, 2015 12:46 AM
uraceulose
Oct 2, 2009 11:45 PM
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
fastdart360
Jan 24, 2008 07:52 AM
