Maintenance Minder Subitems 2 and 3
Old Jun 18, 2009 | 08:52 AM
across55
Default Maintenance Minder Subitems 2 and 3
I have a 2006 Honda Accord SE with approximately 38,000 miles on it. I have been following the maintenance minder for oil changes, etc. Does anyone know approximately how often subitems 2 (replace air cleaner element and dust and pollen filter, inspect drive belt) and 3 (replace transmission fluid) appear on the maintenance minder system (normal driving conditions)? I just want to make sure I haven't missed it already. Thanks for your help.
Old Jun 18, 2009 | 11:00 AM
00AccordLX5spd's Avatar
Registered User
That info would be in the owner's manual that came with the car when you bought it.
Old Jun 18, 2009 | 11:10 AM
across55
The manual says to replace the air cleaner element every 15,000 if you drive in dusty conditions. It also says to replace the dust and pollen filter every 15K if you drive in urban areas with high concentrations of soot. It does not give mileage for normal driving conditions, however.
I know that the mileage will probably differ slightly for each car depending on how the car is driven--I'm just looking for a rough estimate. Thanks.
Old Jun 18, 2009 | 11:22 AM
Registered User
Hmm...that's weird. I just assumed it would be in there (I wasn't trying to be a jerk or anything.)
The normal period for "normal driving conditions" I'm pretty sure is 30k miles for air filter.
As far as belt checking, I'd do it when I changed my oil. (check for cracks and make sure belt(s) is not loose)
Trans fluid is likely at 30k intervals as well.
Old Jun 18, 2009 | 11:43 AM
No, my 2007 Civic doesn't give mileage, it just says to do that whenever #2 or #3 comes up on the maintenance-minder.
On that Civic, #2 just came up at about 22k miles. I haven't seen #3 yet. But I don't know if that stuff is programmed the same way for Civic vs. Accord.
My 2003 Accord calls for engine air filter every 30k miles (doesn't have the maintenance-minder). I think yours has the same filter, so I would think it should have already called for #2. OTOH, the tranny oil intervals were stupid long. Like maybe 100k miles even for the automatic. If I had an auto, I wouldn't wait anywhere near that long.
Old Sep 26, 2009 | 05:27 PM
rhodesmk
I have the code that says to change the dust/pollon filter, but I don't know where it is so I can change it on my 2007 Accord.
Clues, anyone? :-)
Old Sep 28, 2009 | 07:46 AM
It was super easy on my 2003. Probably the same...
Open the glovebox & empty it out.
Unhook the little spring/damper that catches the box.
Maybe have to press the sides of the glovebox to unhook it, allowing it to hinge way WAY down.
Behind the glovebox is a slot that un-clips to open. Pull the filter out.
Otis
Oct 15, 2008 11:36 PM
Otis
Oct 15, 2008 05:06 PM
jackkpts
Feb 19, 2008 02:47 PM
BlackZ51Vett
Sep 28, 2007 03:39 PM
rob3201
Jan 31, 2007 04:46 PM
