Manual Transmission noise???
Old May 9, 2011 | 11:47 AM
blackex19's Avatar
Default Manual Transmission noise???
Hey guys, it's been a while! So my clutch was finally wearing low and i replaced it about 4 days ago...prior to replacing the clutch i had an "airplane" sounding noise whenever i would downshift (most noticeable when downshifting to first gear). I figured that it was the throwout bearing so i bought an OE clutch kit from Oreilly's which included a new throwout bearing and installed it. After replacing, noise did not go away...when im in neutral the noise is there, when i press my clutch in, there is no noise at all...went to the dealer and filled up the tranny with MTF so it's not low on oil....can it be the transmission itself going out? car is up to 190,000 miles now.
Old May 9, 2011 | 07:38 PM
While in neutral, sitting still, is the noise there. Or is this only while the car is moving...or another way, does this only happen while the car is moving or can you make this happen when the car is sitting still?
Old May 9, 2011 | 09:24 PM
blackex19's Avatar
yes, when in neutral and the car is sitting still the noise is there. It only goes away if i fully press my clutch pedal in
Old May 9, 2011 | 11:57 PM
Did the dealership change the transmission fluid or did they top it off?
From your description, the noise has to be coming from the transmission. I don't know if it is internal or something external. What did you use to lubricate the shift fork and the throwout bearing?
Old May 10, 2011 | 10:22 AM
blackex19's Avatar
the dealership drained and refilled the transmission..the only thing that got lubricated was the throwout bearing with a little packet that came with the kit
Old May 13, 2011 | 11:04 AM
blackex19's Avatar
bump...do i got a bad transmission here?
Old May 13, 2011 | 01:31 PM
Noises are tough to diagnose over the web. It sounds like something is up with the transmission. Not sure how to verify the transmission is shot. It may be worth your time to take it to a transmission shop to get their opinion.
Old Mar 15, 2022 | 05:43 PM
mikesanto700's Avatar
So what was it????? Was it the shift fork?????
Old Mar 15, 2022 | 06:51 PM
This is an 11 year old thread. You may not get a response.
Mckinney88
May 1, 2014 10:38 PM
kindway
Sep 3, 2012 07:24 AM
joman
May 18, 2012 07:33 AM
blackex19
Feb 13, 2012 07:16 AM
dabatman99
Nov 17, 2010 03:53 PM
