misfire on all cylinders help
Old Jun 17, 2012 | 09:44 AM
  #21
jfman55's Avatar
Charging system is perfect alternator 14.3. And battery rated for 490 cca and its at 470
Old Jun 17, 2012 | 10:27 AM
  #22
jfman55's Avatar
Everything is perfect alternator charging 14.3 battery rated 490 cca and its at 470
Old Jun 18, 2012 | 12:02 PM
  #23
Don't sweat the part about the codes not resetting.
Beginning in 2003 you can't erase the codes by disconnecting the battery. They began using non-volatile memory for those codes.
They can be cleared with a scan tool, or else they will go away by themselves EVENTUALLY when the problem is fixed.
Last edited by JimBlake; Jun 20, 2012 at 07:58 AM. Reason: Poorman's correct about clearing themselves
Old Jun 19, 2012 | 06:28 PM
  #24
Just to add to what Jim said. I forget the exact number of cycles but the light will go out after a certain number of drive cycles without the issue. So don't think it will go out "right away" once the issue is fixed.
Old Jun 20, 2012 | 09:22 AM
  #25
jfman55's Avatar
I dont understand what you guys are talking about? Before i had them redo the system i had engine codes that i tried to erase with my scanner and they wouldnt go away. After they redid i picked my car up and the codes were gone but the traction control light is on which wasnt on before they redid the wires and the engine codes are gone. But in the process they screwed up and now my traction light is on which wasnt on before. Also did this sat and still on
ehankin
Dec 13, 2014 10:41 AM
Florida_Frank
Feb 16, 2014 07:28 AM
JACQUESFAUST
Dec 10, 2012 06:29 PM
Lil Lewy
Apr 4, 2011 10:13 AM
CLL
Jul 3, 2010 01:58 AM
