Misfiring on Cyl 1 & 2 after EGR port and intake cleaning
Old Jul 19, 2012 | 09:04 PM
geoffm1234's Avatar
I have this exact same problem, and I also posted in this forum and no one has been able to think of a solution.
Old Jul 19, 2012 | 09:53 PM
Just know that your 5th gen IS different than the OP's 6th gen.....close but not really
Old May 19, 2025 | 04:37 PM
Jin3000's Avatar
Default Same issue here,misfire cyl 2 after egr port cleaning
Did the clean got carbon out of ports but gasket was crap so could be culprit i did add some silicone to it.but im the same boat only does it at idle runs great other than that.im assuming i caused a air leak possible at injector or gasket ,which i cant seem to be able to buy as its discontinued.im gonna do a co pression test today but since somone eles having this problem after the same cleaning i dont expect it to be an issue.btw its a 97 f22b.if anyone got ideas on the gasket please send em my way
Old May 19, 2025 | 09:22 PM
The original post was from about 13 years ago, so you may not get help from the original poster. I'd think a vacuum leak would be more pronounced at idle as the engine vacuum is the greatest. Is your engine the f22b1 (ex) or f22b2 (lx/dx)?
Old May 20, 2025 | 06:23 AM
Jin3000's Avatar
Its the f22b.i pulled the plate again cleaned it wasnt very dirt.resealed the gasket as gasket is discontinued.cleaned injectors and checked and lubed seals.reistalled and drove it a couple miles and let it idle at home no light as of yet .i plan on bri gi g it to work tomorrow and thats a 31mile drive one way,so it should happen then if its going to happen at all.i also have a light for oxygen sensor heater ,i dont get that one all the time but every now and then itll pop up,ill be checking that today.its a 97 i bought a year ago drove as is slowly fixing issues as they arise.
Just painted
Just painted
Old May 20, 2025 | 06:24 AM
Jin3000's Avatar
Sorry its a f22b2
Old May 21, 2025 | 06:11 AM
  #17
Jin3000's Avatar
Guess i got it must have been a vacuum leak i sealed it up with rtv and drove it that day and now 31 miles no light.wish they had that egr plate gasket available.thank for the response
huzzsaba
Jan 23, 2008 07:42 PM
dlolstad
Jun 2, 2007 08:55 AM
accordfan222
Jun 1, 2007 08:25 PM
nixalot
Jun 27, 2006 07:50 PM
Antwan
Mar 28, 2006 04:33 AM
