mode motor assemble
Old Sep 7, 2009 | 05:42 PM
galcapfin
Default mode motor assemble
Having trouble with the Mode Motor Assy. in a 2005 Accord LX. Does anybody else have experience with this?
Old Sep 8, 2009 | 08:36 AM
Welcome!
What kind of trouble exactly? I haven't had to take that apart myself, but more information would help us answer.
Old Sep 9, 2009 | 04:39 AM
galcapfin
Jim, as you know the mode motor directs the flow of a/c or heat to the various vents. The only setting I can use without the mode motor from knocking is in the floor vent position. But it still blows from the dash vents. Does this help describe the problem?
Old Sep 9, 2009 | 07:25 AM
The mode motor is #6, but like I said I never had to dismantle that.
Does it sound like the motor is running, but the connection to the actual air doors is broken? It looks like the whole box is "one part" (#3) so it's not real clear to me whether you can get the little things that might be broken.
If the mode motor doesn't run, then look for loose/dirty/corroded wiring. But it seems like 2005 isn't old enough for the wiring harness to be decayed.
Old Sep 9, 2009 | 11:09 AM
galcapfin
Jim, we replaced the mode motor a year ago and that solved the problem. It seems the gears were stripped. But now the problem is back...the motor runs but it can't locate it's stopping points. Something else must be contributing to the problem. What do you think?
Old Sep 9, 2009 | 11:42 AM
Maybe the mode motor has internal limit-switches to make it stop at certain points? Those might be messed up?
I'm just throwing ideas at this point since it never screwed up on my car.
Old Sep 21, 2009 | 06:00 PM
Borbeck
Hi,
i have the 03 Accord. i can not change the mode it only blow out from that dash board.
can you help??
if it is the mode motor you know how much would that be for th cost ??
thanks
Old Sep 22, 2009 | 06:24 AM
go to hondaautomotiveparts.com
click PARTS
put in your car's information
Old Sep 22, 2009 | 11:06 AM
hondadude's Avatar
jaybee74
Apr 22, 2014 02:58 PM
Abhishek719
Nov 27, 2011 11:08 PM
96AccordEXV6
Nov 7, 2006 12:20 AM
nysimonsez
Aug 15, 2006 01:45 PM
92Can_Ex
Jun 30, 2006 11:57 AM
