more issues
so checked the code and came up with four short a pause and then 2 short assume its a 6 water temp sensor is this causeing my issues??? or maybe its 2 codes a 4 and then a 2 crank sensor and o2 sensor??? it was the srs light that did the blinking not the cel
A code 2-4 is a problem with the passenger's air bag on a 95 accord. Not sure if it is the same for a 92EX. This is not causing the starting/stalling problem, so follow the advice above to see if that fixes the problem.
The problem is that I only have the crappy 91 manual that you can download from the online manuals thread in the DIY section to see the 90-93 accord diagnostics.
My 95 shop manual has only a code 2-4, and not a 4-2, so that is what information that I gave you. My suggestion is to pick up a Haynes manual that typically covers one generation of accords. The chilton's manual covers a lot of accords and preludes and is lacking detail specific to your car IMO. The Haynes manual is worth the $20 investment to have as a reference.
YeuEmMaiMai
Oct 17, 2006 04:32 AM
thunder_x
Aug 18, 2006 02:48 AM
