more issues
Old Jan 23, 2011 | 03:58 PM
EXV6NIGHTHAWK's Avatar
Originally Posted by whitetailkiller-2008
so checked the code and came up with four short a pause and then 2 short assume its a 6 water temp sensor is this causeing my issues??? or maybe its 2 codes a 4 and then a 2 crank sensor and o2 sensor??? it was the srs light that did the blinking not the cel
That would be srs trouble codes then, not engine codes. I would get the leaky spark plug tubes fixed, and then replace the plugs and wires (in that order).
Old Jan 23, 2011 | 04:04 PM
A code 2-4 is a problem with the passenger's air bag on a 95 accord. Not sure if it is the same for a 92EX. This is not causing the starting/stalling problem, so follow the advice above to see if that fixes the problem.
Old Jan 23, 2011 | 04:33 PM
whitetailkiller-2008's Avatar
it wasnt 2-4 it was 4 quick flases pause then 2 quick flashes
Old Jan 24, 2011 | 12:21 AM
The problem is that I only have the crappy 91 manual that you can download from the online manuals thread in the DIY section to see the 90-93 accord diagnostics.
My 95 shop manual has only a code 2-4, and not a 4-2, so that is what information that I gave you. My suggestion is to pick up a Haynes manual that typically covers one generation of accords. The chilton's manual covers a lot of accords and preludes and is lacking detail specific to your car IMO. The Haynes manual is worth the $20 investment to have as a reference.
Gwen
Dec 10, 2011 08:35 AM
pace
Apr 17, 2008 04:40 PM
YeuEmMaiMai
Oct 17, 2006 04:32 AM
96hondaaccord
Sep 12, 2006 02:13 PM
thunder_x
Aug 18, 2006 02:48 AM
