My 94 accord AC panel and Fans won't turn on
Old Feb 2, 2017 | 12:30 PM
nponciano's Avatar
Default My 94 accord AC panel and Fans won't turn on
A while back my radiator pop. I replaced it with a new one but now my AC panel does not turn on at all and the fans as well. It drives perferct but when it sits on a red light it heats up till the car moves again. What can be wrong? Does anyone have suggestions?
Old Feb 2, 2017 | 02:46 PM
If under dash heater blower does not turn on you may have a failed blower motor or blower switch. Check fuse 17 (under hood fuse box) for blower and blower motor relay (under dash fuse box).
Overheating may be due to open or disconnected thermoswitch A, failed radiator and condenser fan motors, or electrical fault.
Try removing thermoswitch A connector and shorting connector pins to simulate closed switch. If fans come on, thermoswitch A is bad.
Check for 12V to fan motors at motor connectors w/ thermoswitch A jumper in place. If you have 12V, bad radiator and condenser fan motors.
Jenny Jordan
Dec 22, 2023 11:04 AM
Honda1PR
Dec 6, 2010 11:27 PM
ronski
Aug 19, 2009 10:06 PM
Accord2005v6
Jun 8, 2009 07:01 AM
Fredi95EX
Jun 16, 2005 11:07 AM
